We are working in Windchill 10.1 and Arbortext Editor 6.1. When trying to check in an object the user receives the above CMS diagnostic error. We noticed that the object has a [+] beside its name in the AE browser window. I believe this means the object is saved to the user's local cache. Is there a way to identify the object and retrieve the most recent version to check it into Windchill?
