Can't open file in ProE
Ferromatik
Working with WPPT 1.2 and Wildfire 5.0 M030 un a XPx64 platform.
When I select "OPEN IN PROE" (this is the only way to open a old version ) a new Proe session ist started even I have one running and no files are opened in ProE.
With no ProE running it starts ProE but also not data is loaded in ProE
I found that there should be no spaces in the ProE installation path (wich is default Program Files in WIN7) so I changed Installation, but no success.
Any ideas why this file is not getting loaded in ProE
1. Do you see nmsd.exe (PTC Name service) process in the Windows task manager?
2. Do you use 'proe1.bat' to launch Pro/ENGINEER?
3. Do you use a custom port for PTC Name service?
YES nmsd.exe was started
YES I userd proe1.bt tand the PORT I used was standard.
Now I udpgraded to WF5 M060 ads that fixed the problem,
there seems to be a problem with WF5 M030
A recommended way to use 'Open in Pro/ENGINEER' functionality.
There're two cases - either Pro/ENGINEER is already running and linked to a WPP server, or there's no running Pro/ENGINEER.
The recomended way is the first one.
1. Launch Pro/ENGINEER and be sure to have the intended WPP server registered in it.
2. Navigate to that WPP server using internet browser or embedded browser inside Pro/ENGINEER
3. Execute 'Open in Pro/ENGINEER' command for the interesting model. This can be done for as many models (with different names) as needed and till the Pro/ENGINEER memory allows.
The advantage of this way is:
1. The intended config.pro file can be used
2. Time won't be spent on launching Pro/ENGINEER - the running session is reused
3. The intended version of Pro/ENGINEER can be used (for example, a network installation)
Be aware
1. The functionality depends on PTC Name Service (nmsd.exe). It has to run on the default port.
2. Pro/ENGINEER can have only one model in memory with the same name. Do not try to open different versions of the same model into the same Pro/ENGINEER.
3. The running Pro/ENGINEER version is reused. If another instance of Pro/ENGINEER is launched - then this is an indication of some problems.
