I am starting down the path of upgrading from 10.1 m040 to 10.2 m020. So far looking at the the documentation, it looks like I need another machine to install 10.2 on. What I am trying to do is to install it on the same server that I currently have. I know that is how I did it with the 10.0 to 10.1 upgrade, but I do not even get the Update Existing Installation button. Do I have to have another machine or is there a way to do it on just one machine? If I can do it on one machine, does anyone have a simple outline of the steps that are needed?
Thank you,
Brian
Yes. The upgrade process does not depend on the other system running to do the upgrade. Here is the basic process.
The Windchill install is very much folder centric. You can simply install the new version in a new folder. If you don't want the old install anymore, simply delete the folder.
I'm sure there are some nuances I'm missing, but I think that's the bulk of it.
Tom
Tom
So basically do not install 10.2 to the same folder as 10.1.
I will give that a try.
Thanks!
