We have encountered the dreaded "Cannot retrieve family table neutral data" problem with one of the parts in our database (see https://www.ptc.com/appserver/cs/view/solution.jsp?n=kA1A00000000IUzKAM).
I contacted PTC about this back in February and for some reason they have been unable to provide healing scripts that will run on our SQL Server database to fix the problem. They first sent what were obviously Oracle scripts that didn't work.
Has anyone with a SQL Server database received scripts to correct this issue? Are the scripts customized to your installation? If not, would you mind sharing the scripts?
Thanks.
PDMLink 9.1 M040 with MS SQL Server 2005
Bumping this up since I also could not find SQL related info on this, only Oracle. Have a call into PTC Tech Support and I will post an update here on results so others may be helped too.
Steve, ours was a 3.4 to 10.0 migration. PTC asked for some reports to determine what scripting is needed. I read somewhere else that removing attribute values in a family table could also be a cause. I dont know why someone would want to do that, but who knows. Thanks for the input!
