SPR14611191
The loophole that exists by not processing and filtering Cascading Attributes in certain areas of the system is an obvious miss in implementation. It should be prioritized immediately because there is critical Cascading Attribute logic that we rely on which are missed during Save As or in Creo Workspace/WGM, This issue also exists with load from file/bulkloads.
The business impact can be very diverse. Required attributes not being populated. Invalid attributes being populated. Objects being released with incorrect data. Additional time and steps during Change Management process to manually check for issues. Rework. Inability to perform certain operations from native tools.
Hi , the issue you are facing has been clarified technically (SPR14611191 /Work to spec/No plan to implement ), I think you wanted to post this content in the below board for windchill enhancements :
https://community.ptc.com/t5/Windchill-Ideas/idb-p/WindchillIdeas
