Change Management Tutorial
jfelkins
Hello Windchill Users
I wanted to inform Windchill users that there is a Change Management Tutorial that I written on the below webpage. The tutorial explains the Windchill out-of-the-box functionality with screen shots that displays each step of the process with the Change Management basic workflow. Select on a blue box and you will see a pop up window showing the steps. I hope this helps.
http://www.felcosolutions.com/cm2process.html
The web site also has some other information that explains the CAD Workspace interaction with Windchill and a common Glossary of the Windchill terms. The URL links are below.
http://www.felcosolutions.com/workspace.html
http://www.felcosolutions.com/glossary.html
I hope this helps some of you and you can pass this information on to others too.
Thanks and have a nice day!
Dear James,
Thanks very much. The tutorial on CM was of great help to me.
It would be great if you could throw some light on Windchill UI customization. I am fairly new to WC.
Raghu
The workspace link is the only working link.  The other two are broken.
STEVEG
(To:jfelkins)
@jfelkins
Only one of the links you posted work.
