In our CR process, we have a field that allows us to select multiple functional lists of people to reviewa CR. Some CRs may require 1 group and others may require 3 or 4 groups. We have currently implemented it with all groups getting the email for approval for the next step. We would like to modify the workflow so it will only send email notices to the members of the required functional groups.
Is this possible and if so, does anyone have sample code for the workflow that they can share?
We are on 10.0 M040 at the moment but planning on moving to 10.2 M030 by the end of the year.
Hello Ben,
Have you thought about using a check box tied to attributes in the task before the review? You can use ORs with True or False as the outcome and then it routes it accordingly. You then gather all the results and pass it on to the next task when all are done. Here is what it looks like, it is kind of busy, but it will do what you want.
