Hi All,
I had seen like what ComponentConfigBuilder and ComponentDataBuilder Interfaces in Windchill Customization Guide and the method that are in that interface.
However can anyone share one sample program with an example on how to implement these interfaces. As I had seen in the customization guide there was an example on how to set the values etc. But can any one share any other code or an example like where we can implement ComponentConfigBuilder and ComponentDataBuilder Interfaces.
Thanks in advance.
Best Regards,
Aditya Achanta
Aditya
below is one example of extending AbstractComponentBuilder class which implements ComponentConfigBuilder and ComponentDataBuilder Interfaces
Hope it helps !!!
package ext.sra.mvc;
@ComponentBuilder("ext.sra.PartSearchBuilder")
public class PartSearchBuilder extends AbstractComponentBuilder {
private static int level = 1;
@SuppressWarnings("deprecation")
@Override
public Object buildComponentData(ComponentConfig config, ComponentParams params) throws Exception {
ObjectVector result = new ObjectVector();
String topLevelPartCriteria = (String) params.getParameter("oid");
String name = (String) params.getParameter("name");
JcaComponentParams localJcaComponentParams = (JcaComponentParams) params;
HashMap<String, Object> map = localJcaComponentParams.getHelperBean().getNmCommandBean().getText();
for (Iterator<String> itr = set.iterator(); itr.hasNext();) {
String n = itr.next();
System.out.println(n + "----" + map.get(n));
System.out.println("--AAA--" + localJcaComponentParams.getHelperBean().getNmCommandBean().getPageOid());
System.out.println("--" + topLevelPartCriteria);
System.out.println("--" + params.getAttribute("oid"));
System.out.println("--" + params.getContextObject());
wt.fc.ReferenceFactory oid = new wt.fc.ReferenceFactory();
wt.fc.WTReference ref = oid.getReference(localJcaComponentParams.getHelperBean().getNmCommandBean().getPageOid().toString().split("~")[0]);
NavigationCriteria nc = new NavigationCriteria();
nc.setConfigSpecs(Arrays.asList(new LatestConfigSpec()));
WTPart part = (WTPart) ref.getObject();
QueryResult qr = new QueryResult();
getStructure(part, nc, 1, qr);
return qr;
@Override
public ComponentConfig buildComponentConfig(ComponentParams params) throws WTException {
ComponentConfigFactory factory = getComponentConfigFactory();
TableConfig table = factory.newTableConfig();
table.setLabel("MBOM");
table.setType("wt.part.WTPart");
// make row indd the table selectable
table.setSelectable(true);
table.setActionModel("shreyas_toolbar");
ColumnConfig col = factory.newColumnConfig("Name", false);
table.addComponent(col);
table.addComponent(factory.newColumnConfig("Level", false));
table.addComponent(factory.newColumnConfig(INFO_ACTION, false));
table.addComponent(factory.newColumnConfig("Quantity", false));
return table;
Shreyas
Aditya
Hope it helps !!!
@Override
return qr;
@Override
return table;
Shreyas
