Creating wtParts linked to CAD docs
vmcdaniel
2-Guest
So far I have found with my Windchill 10.0 M030 installation I have a couple of options to begin using wtParts. 1. The Windchill Part Creation Utility Administration Guide<">http://www.ptc.com/view?im_dbkey=124512> can create wtPart, driven from and linked to CAD/EPM documents. 2. The import from spreadsheet can be used to create wtParts and Structure, but does not seem to enable linking a wtPart to a CAD doc.
Our part numbers are in the format 1.234-567.8 but, our Creo parts are numbered 12345678.prt/asm/drw. We want to end up with 12345678.PRT linked to 1.234-567.8 wtPart.
I can easily create all the wtParts in the dot-dash-dot format using the Import from spreadsheet, but I do not know how to link them to the CAD doc, so that method is out. If I use the XML Part Creation from CAD docs, I didn't see anything in there to customize how the number is transferred from the CAD to the wtPart, so that method is out.
So my questions are:
If I already have wtParts, is there a bulk method to link them to corresponding CAD docs?
Or
Do you have suggestions on a procedure that would work for me?
Vaughn McDaniel III | Business Process Analyst - PLM/CAD Applications - IT PMO| Kärcher North America - Hampden | m:720.216.3495 o:303.783.5151*new* | vaughn.mcdaniel@karcherNA.com<">mailto:vaughn.mcdaniel@karcherNA.com> | 750 W. Hampden Avenue - Suite 400, Englewood, CO 80110
[cid:image001.png@01CD39B4.0F206450]<">http://www.karcher.com/usa/Home.htm>
PLM?<">http://en.wikipedia.org/wiki/Product_lifecycle_management> Windchill?<">http://www.ptc.com/WCMS/files/130891/en/flash/index.htm?&im_dbkey=130891&im_language=en> PLM for SMB?<">http://www.ptc.com/WCMS/files/129410/en/flash/index.htm?&im_dbkey=129410&icg_dbkey=362>
0 REPLIES 0
