If anyone has had success with these utilities, could you share an example?
All I would like to do is create a product and library (from an existing template) and also create additional folders/sub-folders into a product/library.
As I practice configuration of Intralink 9.1 M060, I find myself doing tasks repeatedly, and would like to automate as much as is practical. I have been reading the "Data Loading Reference and Best Practices Guide", and it seems that csv2xml and LoadFromFile might be just the tools I need. However, the documentation is clearly incomplete and frequently incorrect, nor is there a simple womb-to-tomb example.
Gerry
Can anyone share some example loadfiles for creating / modifying attributes and soft types?
We want to modify the "Discrete Set Constraint" values for soft type attributes, add or remove attributes to / from soft types, create or rename existing attributes, etc.
Doingdozens of these changesby hand is too tedious, and error-prone! Help!! 😉
I see the first few lines of "csvmapfile.txt" refers to entries that look relevant, but figuring out how to use them - and whether they work - is the question now for me.
