Debugging OIRs
pwilliams-3
11-Garnet
Debugging OIRs
Hi Everyone,
Does anyone know the logger that I need to set to turn on verbose OIR evaluation?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01D072A6.2DE58AE0]
From PTC Knowledge Base:
* In the event JConsole or a similar JMX client fails to work as
expected, it is still possible to enable JMX loggers
1. Open <windchill>/codebase/WEB-INF/log4jMethodServer.properties in a
text editor
2. Edit the file to set the following loggers to DEBUG level as follows
* log4j.logger.wt.access.evaluation.events=DEBUG
* log4j.logger.wt.access.evaluation.policyACL=DEBUG
* log4j.logger.wt.access.evaluation.report=DEBUG
* log4j.logger.wt.access.evaluation.securityLabels=DEBUG
* Refer to Article 78878 :
<">https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS78878> The
differences between the various Access Control related Loggers in Windchill
to evaluate which logger may be appropriate
3. The settings will take effect within a few minutes without a
MethodServer restart
* Verbosities similar to the loggers can also be set by setting the
wt.properties below but is less desirable
* wt.access.verboseEvent=true
* wt.access.verboseExecution=true
* wt.access.verbosePolicy=true
* The above properties can be added to the site.xconf file using
syntax: xconfmanager -s "wt.access.verbose=true" -t
"codebase/wt.properties" -p
* This approach requires a MethodServer restart
Set log level on the wt.rule package ALL
On Apr 9, 2015 9:22 AM, "Williams, Patrick" <->
wrote:
> Hi Everyone,
> evaluation?
> *Patrick Williams* | Engineering Systems | c: 616.947.2110
> [image: sc_inc_black_sig_1_alt]
Thanks everyone. The below classes worked correctly.
setting wt.rule and com.ptc.core.rule to DEBUG should help ...
[cid:image002.jpg@01D072B2.3E9E95F0]
Wow what a miss... Sorry man I misunderstood your question cause
just today I was looking into ACL debugging... My bad! :-#
Em
09.04.2015 11:45, Williams, Patrick escreveu:
> setting wt.rule and
> PATRICK WILLIAMS |
