When creating a new workspace in 10.0m040, the default group is the first alphabetically on the list (Cfg_lib, Doc_lib, Machine, Parts_lib). Is there a way to make the default the Machine group as that is the only group that the Creo users should be using?
Great question, I've often wondered this too. One of our libraries is alphabetically ahead of most products, I've thought of renaming it later in the alphabet, but it would be better to keep the name and simply re-order products first.
Any suggestions welcome!
Edwin
In Reply to Ben Loosli:
