Any inputs on where to locate entry/entries either in WC/Tibco which says the type of view to be sent for publishing to Oracle ERP from Windchill. The test case which I am trying to execute is creating mBOM (using MPMLink) from an eBOM and pushing the mBOM to ERP (through a CN process). I am not sure if the system is intelligent enough to differentiate between design view & manufacturing view.
I just saw this, and I hope you already have your answer; but the default view for a manual publish is set in the distribution target preferences.
One caveat, we had an issue where a downstream view wasn't publishing the correct (or complete) information on the children.
For whatever reason, with the help of PTC support we eventually tracked it down to the need to set a default publishing view on the manufacturing resources, even though we weren't publishing any. Your mileage may vary, but this was in both 10.2 and 11 development systems.
Good Luck,
Casey
