Does anyone know if it's possible to disable exception stack traces in the Windchill log files? These are bloating the logs and (in my opinion) provide no value. Frankly, I don't think Windchill legitimately preventing users from doing something they don't have permission to do (based on ACLs) should be classified as an ERROR. I don't need to see a stack trace every time someone tries to check out something before they revise it. This isn't an ERROR, this is a SUCCESS. Windchill is doing it's job! Can the red text below be suppressed?
2017-03-28 02:47:28,676 ERROR [ajp-nio-127.0.0.1-8010-exec-66] com.ptc.windchill.uwgm.proesrv.action.AddToWorkspaceAction <user> - AddToWorkspaceAction.checkoutToWorkspace :: EPM checkout failed
wt.vc.wip.WorkInProgressException:
Operation failed because the user did not have the necessary permission on the following objects to perform the operation: Drawing - <drawing 1>
Operation failed because the user did not have the necessary permission on the following objects to perform the operation: Drawing - <drawing 2>
Operation failed because the user did not have the necessary permission on the following objects to perform the operation: Drawing - <drawing 3>
Operation failed because the user did not have the necessary permission on the following objects to perform the operation: CAD Part - <part 1>
Operation failed because the user did not have the necessary permission on the following objects to perform the operation: CAD Part - <part 2>
Operation failed because the user did not have the necessary permission on the following objects to perform the operation: Assembly - <assembly 1>
at wt.vc.wip.StandardWorkInProgressService.validateAccessForCheckout(StandardWorkInProgressService.java:3968)
at wt.vc.wip.StandardWorkInProgressService.checkoutMap(StandardWorkInProgressService.java:2226)
at wt.vc.wip.StandardWorkInProgressService.checkoutMap(StandardWorkInProgressService.java:2212)
at wt.vc.wip.StandardWorkInProgressService.checkout(StandardWorkInProgressService.java:1172)
at sun.reflect.GeneratedMethodAccessor1683.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
at com.sun.proxy.$Proxy39.checkout(Unknown Source)
at wt.epm.workspaces.WorkspaceCheckoutManager.checkout(WorkspaceCheckoutManager.java:188)
at wt.epm.workspaces.EPMStandardWorkspaceManager.checkout(EPMStandardWorkspaceManager.java:477)
at sun.reflect.GeneratedMethodAccessor1744.invoke(Unknown Source)
at com.sun.proxy.$Proxy195.checkout(Unknown Source)
at com.ptc.windchill.uwgm.proesrv.action.AddToWorkspaceAction.reservedCheckout(AddToWorkspaceAction.java:525)
at com.ptc.windchill.uwgm.proesrv.action.AddToWorkspaceAction.checkoutToWorkspace(AddToWorkspaceAction.java:473)
at com.ptc.windchill.uwgm.proesrv.action.AddToWorkspaceAction.executeAction(AddToWorkspaceAction.java:1536)
at com.ptc.windchill.uwgm.proesrv.action.UwgmAction.execute(UwgmAction.java:84)
at com.ptc.windchill.uwgm.proesrv.saveas.SaveAsExistingDocumentProcessor.checkoutDocs(SaveAsExistingDocumentProcessor.java:542)
at com.ptc.windchill.uwgm.proesrv.saveas.SaveAsExistingDocumentProcessor.reviseAndCheckoutDocs(SaveAsExistingDocumentProcessor.java:446)
at com.ptc.windchill.uwgm.proesrv.saveas.SaveAsExistingDocumentProcessor.getUpdatedSaveAsInstructions(SaveAsExistingDocumentProcessor.java:246)
at com.ptc.windchill.uwgm.proesrv.saveas.SaveAsExistingNameConflictProcessor.processDocuments(SaveAsExistingNameConflictProcessor.java:426)
at com.ptc.windchill.uwgm.proesrv.saveas.SaveAsExistingNameConflictProcessor.processResolutionOptions(SaveAsExistingNameConflictProcessor.java:304)
at com.ptc.windchill.uwgm.common.conflict.MultiConflictHolder.checkResolutionOptions(MultiConflictHolder.java:98)
at com.ptc.windchill.uwgm.common.conflict.ConflictUtilities.checkConflictsInternal(ConflictUtilities.java:162)
at com.ptc.windchill.uwgm.common.conflict.ConflictUtilities.checkConflicts(ConflictUtilities.java:61)
at com.ptc.windchill.uwgm.proesrv.saveas.SaveAsConflictManager.checkConflicts(SaveAsConflictManager.java:132)
at com.ptc.windchill.uwgm.proesrv.saveas.SaveAsHelper.checkConflicts(SaveAsHelper.java:362)
at com.ptc.windchill.uwgm.proesrv.action.AbstractSaveAsAction.executeAction(AbstractSaveAsAction.java:188)
at com.ptc.windchill.uwgm.proesrv.action.SaveAsToWorkspaceAction.executeAction(SaveAsToWorkspaceAction.java:156)
at com.ptc.windchill.uwgm.proesrv.request.SaveAsRequest.executeSaveAsAction(SaveAsRequest.java:252)
at com.ptc.windchill.uwgm.proesrv.request.SaveAsToWorkspaceRequest.executeRequest(SaveAsToWorkspaceRequest.java:138)
at com.ptc.windchill.uwgm.proesrv.StandardRequestDispatcher.dispatchRequest(StandardRequestDispatcher.java:1311)
at com.ptc.windchill.uwgm.proesrv.StandardRequestDispatcher.scanRequests(StandardRequestDispatcher.java:1061)
at com.ptc.windchill.uwgm.proesrv.UwgmTransactionExecuterImpl.execute(UwgmTransactionExecuterImpl.java:109)
at com.ptc.windchill.uwgm.proesrv.UwgmTransactionExecuterImpl.executeTransaction(UwgmTransactionExecuterImpl.java:59)
at com.ptc.windchill.uwgm.proesrv.task.UwgmTask.run(UwgmTask.java:131)
at com.ptc.core.task.Task.execute(Task.java:262)
at com.ptc.core.task.StandardTaskManager.runTask(StandardTaskManager.java:183)
at com.ptc.core.task.StandardTaskManager.retryTask(StandardTaskManager.java:591)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at com.sun.proxy.$Proxy188.retryTask(Unknown Source)
at com.ptc.core.htmlcomp.console.RetryTaskProcessor.retryTask(RetryTaskProcessor.java:152)
at wt.htmlutil.MethodAction.action(MethodAction.java:132)
at wt.htmlutil.CachedHTMLTemplate.execute(CachedHTMLTemplate.java:162)
at wt.htmlutil.CachedHTMLTemplate.execute(CachedHTMLTemplate.java:123)
at wt.htmlutil.HTMLTemplate.process(HTMLTemplate.java:229)
at wt.templateutil.processor.DefaultTemplateProcessor.handleRequest(DefaultTemplateProcessor.java:524)
at wt.enterprise.URLProcessor.URLTemplateAction(URLProcessor.java:278)
at sun.reflect.GeneratedMethodAccessor968.invoke(Unknown Source)
at wt.httpgw.HTTPServletResponse.invoke(HTTPServletResponse.java:264)
at wt.httpgw.MethodRequestHandler.handleRequest(MethodRequestHandler.java:62)
at wt.httpgw.HTTPGatewayServlet.serviceWithoutFilters(HTTPGatewayServlet.java:336)
at wt.httpgw.HTTPAuthGatewayServlet.serviceWithoutFilters(HTTPAuthGatewayServlet.java:86)
at wt.httpgw.FilterChainImpl.doFilter(FilterChainImpl.java:94)
at wt.session.SessionContextDestroyer.doFilterInternal(SessionContextDestroyer.java:136)
at wt.session.SessionContextDestroyer.doFilter(SessionContextDestroyer.java:184)
at wt.httpgw.FilterChainImpl.doFilter(FilterChainImpl.java:81)
at wt.httpgw.HTTPGatewayServlet.service(HTTPGatewayServlet.java:235)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165)
at com.ptc.jws.servlet.filter.WsdlServletFilter.doFilter(WsdlServletFilter.java:61)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192)
at com.ptc.core.components.filter.JCAFilter.doFilter(JCAFilter.java:97)
at com.ptc.core.ui.validation.URLValidationFilter.doFilter(URLValidationFilter.java:77)
at wt.httpgw.filter.WTContextBeanFilter.doWithWtContextBeanHandler(WTContextBeanFilter.java:104)
at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:58)
at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:294)
at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:335)
at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1660)
at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:56)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:108)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:349)
at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:476)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:802)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1420)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
