Hi All,
Windchill system is allowing the user to iterate the earlier version. Is there any settings to disallow it?.
Example:
A.prt is having versions like 1.0 and 2.0. Now user can able to iterate the both the version like 1.1 and 2.1.
So I need to stop the 1.0 version to iterate. Is it possible in Windchill?.
Thanks in advance for your comments.
Saravanan
PLM Consultant.
In Preferences: Create and Edit > Allow checkout of non-latest iterations = Do not allow.
If they can't check it out, then they can't check it in.
Gerry
In Reply to Saravanan Subramanian:
Windchill system is allowing the user to iterate the earlier version. Is there any settings to disallow it?.Example:
Hi All,
Thanks for the comments.
I am facing issue with non-latest revision (not with non-latest iteration).
So I decided to go with LifeCycle State transition to control the iteration of non-latest revision.
Saravanan
You should put ACLs and Lifecycle Transitions according to State. Like Released not allowed to modify, but revise. Is all your items in work at the previous rev? Thus, if you ACLs and transitions allow you to modify "IN WORK" objects well it is just your process of changing the states of the previous rev. You need a proper release and change control process.
