Two users have confirmed this and I have seen this before years ago I believe with change objects. The user was creating a new part request object. Two were created as a result at exactly the same time and two workflows were spawned. As I have seen this before with other wizards, was there a fix or should this be filed as ticket to PTC? I cannot say if the user clicked something twice or rapidly. I will try to repeat but system should not allow multiple objects to be created if the user gets click happy waiting for response.
its worth to check the Apache access log, if two requests were generated by the client machine
issue tracked with TS IN C17323941
