Epmdocument revise function error
YJ_10068754
hello.
An error occurs in the revise function of Windchill epmdocument.
When the epmdocument and wtpart in the released state are respectively revised, the revision of wtpart is completed.
The error below occurs in epmdocument and cannot be revised. Does anyone know how to resolve this error?
Attaching the error log file.
Hari_Vara
(To:YJ_10068754)
Are they in the same LC state before Revise? Any onscreen error message will be useful other than logs.
Regds
Hari
Please also check the life cycle template assigned to each. Are they using the same template, and is the revise transition configured properly for both?
YJ_10068754
(To:YJ_10068754)
We took action after finding a technical document that stated that revisions were not possible if the load file was not loaded properly. Thank you for your answer.
windchill wt.load.LoadFromFile -d D:\ptc\Windchill_12.0\Windchill\loadFiles\preference.foundation.incremental.x24M020.xml
