Hi all,
I am new to Windchill and also to configuring Windchill to have multiple MS and BGMS.
I've set up a new configuration with 2 MS and 3BGMS.
Right now when i start the Server Manager i get the following error:
2017-03-08 08:53:51,915 INFO [main] wt.server.manager.startup - Registry created: RegistryImpl[UnicastServerRef2 [liveRef: [endpoint:[ch-s-0008278.ch.abb.com:5002,wt.boot.WTRMIMasterSocketFactory@1e240](local),objID:[0:0:0, 0]]]]
2017-03-08 08:53:51,930 ERROR [main] wt.manager.ServerManagerImpl - Failed to create JmxConnectInfo!
sun.management.AgentConfigurationError
at wt.jmx.core.remote.ConnectorBootstrap.checkPasswordFile(ConnectorBootstrap.java:570)
at wt.jmx.core.remote.ConnectorBootstrap.startRemoteConnectorServer(ConnectorBootstrap.java:374)
at wt.jmx.core.remote.ConnectorBootstrap.initialize(ConnectorBootstrap.java:281)
at wt.jmx.core.remote.ConnectorBootstrapUtil.initRemoteJmxConnectorInternal(ConnectorBootstrapUtil.java:97)
at wt.jmx.core.remote.ConnectorBootstrapUtil.getRemoteJmxUrl(ConnectorBootstrapUtil.java:70)
at wt.jmx.core.remote.ConnectorBootstrapUtil.initRemoteJmxConnector(ConnectorBootstrapUtil.java:51)
at wt.method.jmx.JmxConnectInfoHelper.<clinit>(JmxConnectInfoHelper.java:51)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:191)
at wt.manager.ServerManagerImpl.<clinit>(ServerManagerImpl.java:123)
at wt.manager.ServerManagerMain.startServerManager_internal(ServerManagerMain.java:367)
at wt.manager.ServerManagerMain.run(ServerManagerMain.java:295)
at wt.manager.ServerManagerMain.main(ServerManagerMain.java:225)
Do you have any idea how i can fix this?
Alex
Looks like one of the startup commands has incorrect values. Could you let us know the changes you made to the properties to add more MethodServer or may be attach the wt.properties file?
Hi Kumar,
Indeed there was a problem with the Server Manager "wt.manager.cmd.ServerManager.jmx.args" property. The -Dwt.jmx.rmi.minPort and -Dwt.jmx.rmi.maxPort values were not correct. For now I removed this property and will update the .xconf file when there is more data about what the client needs.
Alex
good work bro
it is working for me
Thanks a lot the help.
