We are currently in the process moving from WC9.1 to WC10.1. We currently have many Windchill reports, created in report builder which we view and post process in Excel, using web query. In WC10.1 the reports generated are no longer pure HTML. It would appear this now stops us using web queries in Excel.
Looking through PTCU posts, it seems we are not the only people to use web query in Excel, so I was wondering if anybody has stumbled on this problem.
Darren
I am having another issue related to this. When I refresh the connection, an error with something about not connecting to URL due to basic authentication vs. SSL...."Unable to open <url>. The hyperlink cannot be followed to the destinations "
I foundhttps://support.ptc.com/appserver/cs/view/solution.jsp?n=CS162869 which suggest the "Legacy Mode" solution, however, there is a link to an MS page that goes on to explain how the registry must be changed.
Any clue about this?
I am using WC 10.1 m010 and there is no "Legacy Mode" option (apparently not until m040), will this help me get past this without having to mess with the registry for everyone who uses the spreadsheet.
Thanks in advance,
Cam
Cameron,
take a look at this article from TS.
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS162869&lang=en
Marco,
If you look at my previous post, I am referring to the same document you mention. There is a link to an MS solution in the final step.
Cam
