I have created a number of fault trees, set parameters and run the FTA model. I have my FTA results. I wish to see the cut sets of my fault tree and have used the highlight cut sets feature. Relax shows me a cut set list in one single column which is not useful when I wish to see the minimum cut set in the diagram to send to our customer.
Does anyone know how I can export the minimum cut set and relate the list to the diagram so I can send them to our customer?
Duncan,
-make sure that you checked the "cut sets" check box in the calculation section, then calculate the fault tree.
- right click the top gate / properties.
- select the cut sets heading. A tabular representation of all cut sets will be displayed.
Note the "Excel" button at the bottom of the window.
Duncan,
make sure that you enabled the "cut set" check box in the calculation section.
Right click the top gate / properties:
Note that Excel button.
