Hi All,
I had created a series in this way as I had started a discussion regarding the same.
File Based Series : The series or seed is undefined
However I even wish to remove the delimiter say for suppose as upon revising or check out and check in it gets modified as V1.1 V1.2
So I dont want that delimter dot (.) to be there. I had seen the PTC Tech support portal for this and found few cases
Step 1.)
I went to wt.properties file and found the property. I made two modifications in wt.properties file
wt.series.HarvardSeries.delimiter=.
So I removed the dot and equaled it with nothing as
Step 2.)
wt.series.HarvardSeries.depth=16
So I updated the depth as 99
wt.series.HarvardSeries.depth=99
But after this the method server failed starting which is showing an error like
2016-05-12 11:36:27,662 INFO [main] wt.system.err Administrator - Error initializing wt.series.HarvardSeries
2016-05-12 11:36:27,701 INFO [main] wt.system.err Administrator - java.lang.StringIndexOutOfBoundsException: String index out of range: 0
2016-05-12 11:36:27,721 INFO [main] wt.system.err Administrator - at java.lang.String.charAt(String.java:686)
2016-05-12 11:36:27,723 INFO [main] wt.system.err Administrator - at wt.series.HarvardSeries.readStaticProperties(HarvardSeries.java:1042)
2016-05-12 11:36:27,728 INFO [main] wt.system.err Administrator - at wt.series.HarvardSeries.<clinit>(HarvardSeries.java:164)
2016-05-12 11:36:27,729 INFO [main] wt.system.err Administrator - at java.lang.Class.forName0(Native Method)
2016-05-12 11:36:27,751 INFO [main] wt.system.err Administrator - at java.lang.Class.forName(Class.java:171)
2016-05-12 11:36:27,752 INFO [main] wt.system.err Administrator - at wt.series.Series.getClassForName(Series.java:309)
2016-05-12 11:36:27,752 INFO [main] wt.system.err Administrator - at wt.series.MultilevelSeries.newMultiLevelSeriesFromSeriesName(MultilevelSeries.java:554)
2016-05-12 11:36:27,753 INFO [main] wt.system.err Administrator - at wt.series.MultilevelSeries.newMultilevelSeries(MultilevelSeries.java:210)
2016-05-12 11:36:27,754 INFO [main] wt.system.err Administrator - at wt.vc.VersionControlHelper.<clinit>(VersionControlHelper.java:141)
So how to remove the delimiter for the custom_series class that I had created.
Thanks in advance. Kindly let me know
Thanks and Regards,
Aditya Achanta
Hi All,
Can you please help me out like how to resolve this problem in delimiter.
Actually I had attached one more post to this particular query and I was in a position to create a new File Based Versioning Scheme. However if I wish to remove the delimiter like what should I be doing can you please let me know about it once ?
Thanks and Regards,
Aditya Achanta
Archana,
I don’t know your exact business requirement to implement this. If your requirement is
It always risk to play with versioning series.
Hope it helps!!!
Shreyas
