As per the new PTC® System Monitor Installation and Usage Guide PTC System Monitor 2.0 F000 pp 102....
"...Note
The HTML-based access has most of the functionality that is in the full Java client. It is intended for reporting and viewing dashboards by users or managers, and also for administrative monitoring using mobile devices that do not support a full Java client. The full client is not bundled with the download; PTC recommends using the Webstart Client. If you want a full client, contact PTC Technical Support..."
I thought everyone would like to know this little tidbit.
Enjoy,
OK So the Full featured client is the Java file you download when you access the Web interface. You do not need to contact Tech support at all.
Andy,
Just to clarify the confusion around different clients. Basically there are three ways to use PSM on the client side:
In above snippet the full client is referred to as the local installed client.
Reinhard
