Good morning,
I am a new user to WIndchill PDM Essentials 10.2 and I need some help.
Can someone point me in the direction of where I can find help on generating reports or tables based on information stored in PDM Essentials?
For example:
I want to generate a table with critical characteristics for components in a specific folder in a library:
(The required information is stored in part and sub-assembly models via parameters.)
Foldername:
Boxes
Filenames:
55_Box_A_Green
58_Box_B_Yellow
63_Box_C_Blue
Etc...
Critical characteristics:
Parameter "Length"
Parameter "Width"
Parameter "Height"
Parameter "Width"
Parameter "Thickness"
Parameter "Material"
TYIA for your help.
~Benito
