Getting Affected Objects on a Variance
MikeIbosh
Hi all,
I'm working on a Windchill 10.1 M030 system, and I need get the affected objects that are on a Variance workflow process? Does anyone have the transition code that will return a query result with these objects? Any help is much appreciated.
Mike
Hi I am looking into buying a small form device to make working on plans
easier since I spend a lot of time on them 😞
Things that I want to do with it that involve Windchill
- Develop - Run Multiple VM Kernals if possible
- Run Windchill front end (Proe is nice, but not really required)
- OS - Open I can cope with Windows, Unix, Maybe IOS
- Possibly VPN connection
- Office tools
- Word, Project, Access ... (code be run in VM if needed)
- I am pretty sure I will need a USB port(s)
- 16-32G memory
- 500k - 1T (or more) disk space
I have had many many laptops but I really want something smaller than a
traditional laptop.
If you have any experience doing mobile Windchill work with a smaller
footprint device like this please let me know.
--Bob
ChrisWatson
(To:MikeIbosh)
Bob,
Do you need access to the VMs at all times? If you can cope with on-line access then you could look at putting the VMs on Amazon and cutting the device specs and hence the physical form factor/cost.
Chris
