Hello All,
I'm performing a rehost of Windchill 10.2 M030 using the Rehost Utility.
I've manually exported/imported MS SQL Database from our Production Server to Test server and manually copied the vaults and the Windchill install loadpoints. I run the rehost utility and half way through I'm getting an error
[vaulttask] com.ptc.wc.rehost.exception.RehostException: com.microsoft.sqlserver.jdbc.SQLServerException: Cannot insert duplicate key row in object 'windchill.FvHost' with unique index 'FvHost$UNIQUE55'. The duplicate key value is (Uxxxxxxxx.int.xxxx.net).
[vaulttask] Nested exception is: com.microsoft.sqlserver.jdbc.SQLServerException: Cannot insert duplicate key row in object 'windchill.FvHost' with unique index 'FvHost$UNIQUE55'. The duplicate key value is (Uxxxxxxxx.int.xxxx.net)
I just wanted to know if anyone has seen this error message before. Any ideas or suggestions would be helpful.
Kiran
