Got an IllegalStateException: unread block data while Querying on WTPart
vuchekar
9-Granite
Hi All,
I need to export all WTparts from Windchill DB, so i used below code, it previously works but it suddenly gives an such errors,, i also observerd that it related to only WTPart.. any query on WTPart is not Working.. each query gives same error: java.lang.IllegalStateException: unread block data
my Query is here..
QuerySpec qs = new QuerySpec(WTPart.class);
QueryResult qr = PersistenceHelper.manager.find(qs);
while (qr.hasMoreElements()) {
prt = (WTPart)qr.nextElement();
cName = prt.getContainerName();
partNum = prt.getNumber();
system.out.println("*******" +partNum);
Exception in thread "main" java.lang.IllegalStateException: unread block data
at java.io.ObjectInputStream$BlockDataInputStream.setBlockDataMode(ObjectInputStream.java:2419)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1380)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:370)
at wt.method.MethodResult.readExternal(MethodResult.java:152)
at java.io.ObjectInputStream.readExternalData(ObjectInputStream.java:1835)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1794)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1348)
at sun.rmi.server.UnicastRef.unmarshalValue(UnicastRef.java:324)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:173)
at wt.method.MethodServerImpl_Stub.invoke(Unknown Source)
at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:647)
at wt.services.ServiceFactory$ClientInvocationHandler.invoke(ServiceFactory.java:349)
at com.sun.proxy.$Proxy0.find(Unknown Source)
at ext.util.WindVUtil.getLatestParts(WindVUtil.java:690)
at ext.util.ExportParts.exportParts(ExportParts.java:125)
at ext.util.ExportParts.main(ExportParts.java:101)
7 REPLIES 7
Hi, have you found a solution?
sray
(To:vuchekar)
Hi, I'm facing this exception too (for EPMDocuments). Have you found a solution?
vuchekar
9-Granite
(To:sray)
Hi Sampurna,
Sorry, I also not able to find the solution for this.
Vivek.
LoriSood
(To:vuchekar)
It looks like the method is being invoked remotely, correct?
Are the following helpful at all?
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS72059
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS177598
sray
(To:vuchekar)
Hi Lori,
Thanks so much for the help! I was hoping we could at least catch the IllegalStateException so that it doesn't interrupt my execution. However this exception refuses to be caught. The first link you suggested (https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS72059‌) helped in changing the Exception (we are doing a similar thing with EPMDocumentMaster), but even the new WTRemoteException could not be caught.
Sampurna
jessh
(To:vuchekar)
My first guess would be that your client and server classes do not match in some nuances of serialization format, i.e. that you have different class files on your client and server and the server is writing more or less than the other expects to read.
sray
(To:vuchekar)
Hi Jess,
In my case the client and the server are one and the same. Using API, I am attempting to read one EPMDocument number at a time from a .txt file and deleting that EPMDocument (and all objects in its ReferencedBy and UsedByReference list). For most EPMDocuments, the deletion is working fine. For about 1 in 500 EPMDocuments, we are facing IllegalStateException
at java.io.ObjectInputStream$BlockDataInputStream.setBlockDataMode(ObjectInputStream.java:2421)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1382)
at wt.method.MethodResult.readExternal(MethodResult.java:153)
at java.io.ObjectInputStream.readExternalData(ObjectInputStream.java:1837)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1796)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1350)
at sun.rmi.server.UnicastRef.unmarshalValue(UnicastRef.java:325)
at sun.rmi.server.UnicastRef.invoke(UnicastRef.java:174)
at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:646)
at com.sun.proxy.$Proxy11.navigateReferencedBy(Unknown Source)
at ext.audco.utility.EPMDocumentMassDeleteUtil.getEPMDocReferences(EPMDocumentMassDeleteUtil.java:197)
at ext.audco.utility.EPMDocumentMassDeleteUtil.processInputFile(EPMDocumentMassDeleteUtil.java:119)
at ext.audco.utility.EPMDocumentMassDeleteUtil.main(EPMDocumentMassDeleteUtil.java:348)
and that is interrupting the execution. I was wondering if we could catch this exception so that the program continues to run. We have attempted using try..catch, throws, https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS72059‌, using UTF-8 explicitly instead of ANSI and using FileReader instead of InputStreamReader
Thanks so much,
Sampurna
