How can send Email attachments through code with API wt.mail.EMailMessage.addAttachments ?
jchan
3-Visitor
wt.mail.EMailMessage message = wt.mail.EMailMessage.newEMailMessage();
message.setSubject("Mail Subject");
message.addRecipient(user,1);     //recipients paramInt = 1
message.addRecipient(boss,2); //ccRecipients paramInt = 2
message.addAttachments(??????); //Help Me
message.setOriginator((WTPrincipal)wtsender);
message.addPart("Mail Content","text/html");
message.send(true);
syadala
(To:jchan)
Hi James Chan,
            You need to define a String array and populate your object references in there. then try.
String[] attachments = new String[1];
attachments[0] = "add reference to your object";
message.addAttachments(attachments);
message.send(true);
I have not tried this one. If you think it is not working then you can try using javax.mail.internet.MimeMessage
Sudhakar
jchan
3-Visitor
(To:syadala)
String[] strArrayOfString = new String[1]; ;
strArrayOfString[0] = "VR:wt.doc.WTDocument:488784";               // What data type could add reference to the object? It can't work.
strArrayOfString[0] = "D://ptc//Windchill//Windchill//null.log";        // What data type could add reference to the object? It also can't work.
WTUser wtsender = getUserFromUserName("Administrator");
message.addAttachments(strArrayOfString);
Test fail!
syadala
(To:jchan)
Hi James Chan,
           Please let me know what you are intending to send? A Windchill Object or a file?
Sudhakar
jchan
3-Visitor
(To:syadala)
Hi Sudhakar,
We need to send email for user with attached file.
These files will be the primary content and attachments from the WTDocument, or database query results after export to excel file.
I want to use Windchill OOTB API to implement for this user requirement.
Thanks !
Best Regards,
James Cha
Hi All,
Any update on this thread?
EMailMessage mail=EMailMessage.newEMailMessage();
mail.setSubject("For Windchill test");
mail.addRecipient(user);
mail.addPart("Hellllllllllllllllo ","text/html");
String attachement[] = new String[1];
attachement[0] = "C://Users//660588//Desktop//a.pdf";
mail.addAttachments(attachement);
mail.send(true);
Mail is delivered but  without attachement. pls provide help on this
You can use javax.mail.* API instead of wt.mail.*  to send email with attachment below is sample method i used to send email with attachment
public static void sendEmail( String cSVfileName, String fileName2) throws WTException, IOException {
  String thePath = null;
  Properties prop = new Properties();
  FileInputStream input = null;
  String theWTCodebaseHome = WTProperties.getLocalProperties().getProperty("wt.codebase.location");
  theWTCodebaseHome = theWTCodebaseHome.replace('\\', '/');
  thePath = theWTCodebaseHome + "/ext/email.properties";
  input = new FileInputStream(thePath);
  prop.load(input);
  String to  = prop.getProperty("EMAIL.TO", "shreyas.atre@bwir.com").trim();
  // Sender's email ID needs to be mentioned
  String from = prop.getProperty("EMAIL.FROM", "postMaster@abc.com").trim();
  // Assuming you are sending email through relay.jangosmtp.net
  String host = prop.getProperty("EMAIL.HOST", "localhost").trim();
  Date date = new Date();
  SimpleDateFormat sdf = new SimpleDateFormat("MM-dd-yyyy hh:mm:ss");
  sdf.setTimeZone(TimeZone.getTimeZone("America/Chicago"));
  String strDate = sdf.format(date);
  Properties props = new Properties();
  props.put("mail.smtp.auth", "false");
  props.put("mail.smtp.starttls.enable", "false");
  props.put("mail.smtp.host", host);
  props.put("mail.smtp.port", "25");
  // Get the Session object.
  Session session = Session.getInstance(props);
  try {
  // Create a default MimeMessage object.
  Message message = new MimeMessage(session);
  // Set From: header field of the header.
  message.setFrom(new InternetAddress(from));
  // Set To: header field of the header.
  message.setRecipients(Message.RecipientType.TO, InternetAddress.parse(to));
  // Set Subject: header field
  message.setSubject("EMAIL SUBJECT - " + strDate);
  // Create the message part
  BodyPart messageBodyPart = new MimeBodyPart();
  // Now set the actual message
  messageBodyPart.setText("Please see the attached files.");
  // Create a multipar message
  Multipart multipart = new MimeMultipart();
  // Set text message part
  multipart.addBodyPart(messageBodyPart);
  // Part two is attachment
  boolean zipExist = false;
  boolean csvExist = false;
  File tempFile = new File(fileName2);
  if (tempFile.exists()) {
  System.out.println(fileName2);
  DataSource source = new FileDataSource(fileName2);
  messageBodyPart.setDataHandler(new DataHandler(source));
  messageBodyPart.setFileName(strDate + ".zip");
  zipExist = true;
  tempFile = new File(cSVfileName);
  // String filename = "D:\\temp\\atest.zip";
  System.out.println(cSVfileName);
  cSVfileName = createXLSFile(cSVfileName);
  DataSource source = new FileDataSource(cSVfileName);
  messageBodyPart.setFileName(strDate + ".xls");
  csvExist = true;
  // Send the complete message parts
  message.setContent(multipart);
  Address[] allrec = message.getAllRecipients();
  for (Address ad : allrec) {
  System.out.println(ad);
  // Send message
  Transport.send(message);
  System.out.println("Sent message successfully....");
  } catch (MessagingException e) {
  throw new RuntimeException(e);
Hope it helps!!!!
Shreyas
