An error occurs when deleting a specific object.
Associated with change request object ... or associated with promotion object ...
The Retry option does not have an option called Retry after Deleting associated Object.
If I delete an object associated with a change request, do I have to manually delete the change request object and then delete the object again?
Can not delete with associated objects at once?
any other suggestions?
thanks
You will need to work backwards to delete objects in Windchill.
If it is referenced by a change request or promotion request, delete those first.
Next to delete is the drawing file, then any assemblies that reference the part.
Finally you may delete the part object.
HOWEVER
The files must not be in any workspaces.
If you have checked in any assembly or drawing, every iteration must be deleted, working from the latest.
Windchill does not want you to delete objects so to do so is very complex and must be done in a strict order.
There are many references among associated objects, it is not easy to delete associated objects at once.
HOWEVER
really thank you~!!
