Hi All,
My requirement is to add the following constraint to an attribute of type "Real Number" in type and attribute manager
This field is required to 5 digits length (including of decimal point) and only keep 2 digits after point.
I have tried using the valid range constraint like - 0.0000 to 999.99. But still the attribute is accepting values like 189.92567.
Please do help me to achieve this.
Thanks in advance
Archana
