How to calculate the number of documents having a specific attribute value in a Report?
ptc-4698385
I am working on Reports functionality of Windchill10.1
I need to retrive the total number of documents which have the same value for a given attribute in every attribute.
For example: There is an attribute(IBA) called Color in every document.
Now...we need to retrieve the % of the documents having the color blue.
Assume there are 10 documents out of which 4 have the color blue.
Now.. I am able to retrive the documents having the value for color as blue.
But I am not able to calculate the % of these documents.
I tried some wark-arounds like trying to count the number of documents,etc..but I am not getting the desired result.
If anyone could help, It would be of great help.
Thanks and regards,
Shweta Joshi
Hi Guys..
Any help will be highly appreciated...
I need to find the solution as soon as I can..
Thanks and regards,
Shweta Joshi
Could Advance Search can solve your purpose?
No...I am trying to achieve this through Query builder..
Set up your query builder report:
- Set the criteria for the attribute on the criteria tab
- On the Select tab select the document object id, then apply the Count function to it
Hi..
I already did that...I was looking to calculate the % .
Anyway thanks for your help guys.. I found a work-around though..
You can find the % by using the Add a Chart option.
Following is the screenshot of the end result:Percentage.bmp
I am not very sure about the chart. For some reason it doesn't select all the values if the report is too large.
I like doing it the old way, i.e. export to excel and a insert a pivot table
Pardeep
