How to drive Quantity of an item in a BOM based on Options & Variants rules?
Prabhu
7-Bedrock
With Options & Variants capability in windchill 9.1, how we can build the rules (Parameters, expressions, constraints, case tables, etc.,) to drive the quantity of an item under an Advanced Configurable Part?
Example:
Consider below BOM:
Top_Part (Adv Config Part)
Part1 (for option1) Qty - 1
Part2 (for option2) Qty - 2
Part3 (for both options) Qty - 2 Meters for Option1 and 5 Meters for Option2
While configuring, selecting option1 should result in:
Top_Part
Part1 Qty - 1
Part3 Qty - 2 Meters
Selecting option2 should result in:
Top_Part
Part2 Qty - 2
Part3 Qty - 5 Meters
Can you please help in this?
Prabhakaran V.
It's possible by speciying qty parameter in BOM structure on Uses:
GregOlson
(To:hdamle-2)
Do you know if this is possible in 10.2 M030, if yes can you provide steps to reproduce the parameter in Quantity?
I haven't tried on 10.2 (11.0 is what I tried) but if you can load the sample Options and Variant loader it shall be self explained, just make sure to set PSE preference and open the config module in PSE
GregOlson
(To:hdamle-2)
I do not have access to the sample, could you post some screen shots of the expression and how to setup.  I have looked at help and am still confused, would save me a ton of time and be greatly appreciated.
Greg
rkayasth
6-Contributor
(To:GregOlson)
Greg,
Did you get an answer on loading the sample Options & Variants.
I am on 10.2 M030. Do I have any luck on getting the sample into the system??
Ravin kayasth
GregOlson
(To:rkayasth)
I did not receive an answer.
