How to get a report of the URL address of WTparts?
dfrancisco
Hello community!!!
I am trying to get a report that list de URL address of WTParts. I have tried some joins between Part e URL link in query build report without success.
Does anybody knows how to do it?
Thanks a lot in advance...
Binesh,
I ran across the solution.   For MS SQL you basically have to convert the branch identifer to text.
10 REPLIES 10
If you want just the Windchill Information link you can just add the top level object type to the select list. If you are looking to get the actual URL use concat function and generate URL using branch identifier.
Thank you
Binesh Kumar
Medtronic - MITG
Hello Binesh
I exchanged the server name and tried to execute, but unfortunatly it did not work. Take a look at the message:
Thank you in any case.
Hello Daniel,
Could you try recreating a new query from query builder? The only table in From is Part and the the select should be as I have in my screenshot
Thank you
Binesh Kumar
Medtronic - MITG
Binesh Kumar,
I am trying to do the same thing, only for WTDocuments.  When I add the Branch Identifier into the Concatenate function, the report ceases to function.
Any ideas on what I am doing wrong?
Hello Mark,
Are you getting any error? Your QML works fine on my dev system by removing the criteria. I know SQL server has some issues with functions in report manager.
Thank you
Binesh Kumar
Medtronic - MITG
No error.  The report just doesn't return any results.
We are running MS SQL so maybe that is the issue.
Binesh,
BhushanNehe
(To:mdebower)
Hi Daniel,
Can you check if the solution from Marc works for you.
Bhushan
Hi Bhushan
It is works now. At least for WTParts.
Hello Marc
I followed your instructions using the train of thought for WTParts and it works!
Thank you.
Thank you everybody to contribuite to my question.
I confess. I am not a IT professional and your help is very appreciated.
Best Regards.
