Step 1
Make a folder list and save as .csv file under the directory of %WT_HOME%/src/loadFiles/
File name: folder1.csv
SubFolder,,/Default/Design
SubFolder,,/Default/Design/Camry104 : B6 5.5G ICP Dry Ahser CONTROL PROGRAM,
SubFolder,,/Default/Design/Camry101,
SubFolder,,/Default/Design/Camry101/BASELINE,
SubFolder,,/Default/Design/Camry107 : SFA TRULY 4.5G PT CONTROL PROGRAM,
SubFolder,,/Default/Design/Camry105 : G5 Model Navigation CONTROL PROGRAM,
SubFolder,,/Default/Design/Camry103 : B4 Model Navigation CONTROL PROGRAM,
SubFolder,,/Default/Design/Camry100,
Step 2
Change csv to xml. Execute the following command on Windchill Shell:
windchill wt.load.util.CSV2XML -input folder1.csv
Step 3
Load a folder list to a product container. Execute the following command on Windchill Shell:
Windchill wt.load.LoadFromFile -d <Directory Location> -CONT_PATH /wt.inf.container.OrgContainer=<Organization Name>/wt.pdmlink.PDMLinkProduct=<Product Name>/ -u <User Name> -p <Password>
Exmaple:
Windchill wt.load.LoadFromFile -d %WT_HOME%/src/loadFiles/folder1.xml -CONT_PATH /wt.inf.container.OrgContainer=Toyota/wt.pdmlink.PDMLinkProduct=Camry2016/ -u orgadmin -p orgadmin
