Hi guys,
In order to solve a problem of method server start, I have to do the request:
select WTKEY_SEQ.nextval from dual
I have to do it until its value reaches 163553 but now it is only 139082. Each time I do the request, the value increments of 1.
I don't know very much about SQL and I would like to know if there is syntax to make a loop of this request until it reaches the correct value.
Thank you very much.
Florent
Rather than looping the statement, it would be easier to just change the increment value for the sequence. The statement to change the increment value is:
Alter sequence WTKEY_SEQ increment by <New Increment Value>;
Just replace '<New Increment Value>' with the difference between the current sequence value and the value you want the sequence to be. After changing the increment value, then you just need to run 'select WTKEY_SEQ.nextval from dual' once, and it will increment to your target value. Afterward, make sure to set the increment value back to 1, by running:
Alter sequence WTKEY_SEQ increment by 1;
