I want to rehost a production platform from my customer to my company but my customer uses an Active directory. He agrees to give me an LDIF export from Active Directory to import it in my company Active Directory.
Is it possible in the rehost utility (v3.0) to make this update ?
thx
Romain
If you want to make only the testing server then you can turn off the enterprise adapter in the property - wt.federation.org.directory Services, otherwise its must be reconfigured.
I usually do not use the rehost utility. )
