How to search EPMDocument in folder or container using WC APIs
ptc-4576665
I want to search all EPMDocuments in a folder or container using Windchill API (QuerySpec). I do not want to use webjects. How can I do it?
7 REPLIES 7
I want to search All EPMDocuments under a folder. Query should take Folder path or container name as input and output should list all EPDocumets under that folder.
Hi Amit,
QuerySpec querySpec2 = new QuerySpec(EPMDocument.class);
/*SearchCondition condition = new SearchCondition(ContainerTeam.class,ContainerTeam.NAME, SearchCondition.LIKE,"%Sample_Product_02");
querySpec2.appendWhere(condition);*/
QueryResult queryResult2 = PersistenceServerHelper.manager.query(querySpec2);
while (queryResult2.hasMoreElements()) {
EPMDocument epmDocument = (EPMDocument) queryResult2.nextElement();
System.out.println("Part Name : "+ epmDocument.getCADName());
it only takes all the cad names (EPM Document).
but i cant able to fullfill your requirement.
Thank you
Vijayan
KD
(To:vmg)
Try this may be it'll help
QuerySpec qss = new QuerySpec(EPMDocument.class);
EPMDocument doc = null;
qss.appendWhere(new SearchCondition(EPMDocument.class,EPMDocument.CONTAINER_NAME,SearchCondition.EQUAL,"<your container name>"),new int[] { 0 });
qss.appendAnd();
qss.appendWhere(new SearchCondition(EPMDocument.class,EPMDocument.FOLDER_PATH,SearchCondition.EQUAL,"<your folder path>"),new int[] { 0 });
QueryResult qrr = PersistenceHelper.manager.find((StatementSpec)qss);
while(qrr.hasMoreElements())
doc = (EPMDocument)qrr.nextElement();
Message was edited by: kaushik das
ptc-4576665
(To:KD)
Thanks Kaushik but I Getting below error.
It is for the line
wt.query.QueryException
(EPMDocument.class,EPMDocument.CONTAINER_NAME,SearchCondition.EQUAL,"mytest2"),new int[] { 0 });
: Attribute "containerReference.name" is not a member of class "class wt.epm.EPMDocument"
Nested exception is: Attribute "containerReference.name" is not a member of class "class wt.epm.EPMDocument"; nested exception is:
(wt.pom.pomResource/0)
wt.pom.PersistenceException
: A persistence error occurred. System message follows:
Nested exception is: (wt.introspection.introspectionResource/2)
wt.introspection.WTIntrospectionException
: containerReference.name column not found for V_EPMDocument.
at wt.introspection.DatabaseViewInfo.getColumnDescriptor(
DatabaseViewInfo.java:302
at wt.pds.DatabaseInfoUtilities.getValidColumnDescriptor(
DatabaseInfoUtilities.java:339
DatabaseInfoUtilities.java:377
at wt.pds.DatabaseInfoUtilities.getPersistableColumnDescriptor(
DatabaseInfoUtilities.java:666
at wt.query.ClassAttribute.validate(
ClassAttribute.java:1054
at wt.query.ClassAttribute.setAttributeName(
ClassAttribute.java:218
at wt.query.ClassAttribute.<init>(
ClassAttribute.java:468
at wt.query.SearchCondition.initialize(
SearchCondition.java:2234
at wt.query.SearchCondition.<init>(
SearchCondition.java:1433
SearchCondition.java:1388
at com.slb.test.EPMSearch.main(
EPMSearch.java:51
KD
(To:ptc-4576665)
String path = doc.getFolderPath();
if(doc.getContainerName().equalsIgnoreCase("<your container name>")==true && path.substring(0,path.lastIndexOf("/")).equalsIgnoreCase("<folder name>")==true)
//System.out.println(doc.getContainerName());
<your code >
//System.out.println();
KD
(To:KD)
QuerySpec queryspec =
queryspec.setAdvancedQueryEnabled(
true);
int contIndex = queryspec.appendClassList(PDMLinkProduct.class,false);
SearchCondition sc1 =
new SearchCondition(EPMDocument.class, "containerReference.key.id",PDMLinkProduct.class, wt.util.WTAttributeNameIfc.ID_NAME);
queryspec.appendWhere(sc1,
new int[] { 0, contIndex });
queryspec.appendAnd();
SearchCondition scSWPart =
new SearchCondition(PDMLinkProduct.class ,"containerInfo.name",SearchCondition.EQUAL,"<your product name>",true);
queryspec.appendWhere(scSWPart,
new int[] { contIndex });
QueryResult queryResult = PersistenceHelper.
manager.find((StatementSpec)queryspec);
System.
out.println("Size :- " + queryResult.size());
vuchekar
9-Granite
(To:KD)
Hi Kaushik,
Above code is working perfect for Product, but for WTLibarary, i have create similar method, but i am getting "wt.query.QueryException: Attribute "containerReferene.key.id" is not a member of class "class wt.part.WTPart"
here is Program,
Please guide me to solve this error,
import wt.doc.WTDocument;
import wt.epm.EPMDocument;
import wt.fc.Persistable;
import wt.fc.PersistenceHelper;
import wt.fc.QueryResult;
import wt.inf.library.WTLibrary;
import wt.lifecycle.LifeCycleHelper;
import wt.lifecycle.LifeCycleState;
import wt.part.WTPart;
import wt.pdmlink.PDMLinkProduct;
import wt.pds.StatementSpec;
import wt.query.CompositeQuerySpec;
import wt.query.QueryException;
import wt.query.QuerySpec;
import wt.query.SearchCondition;
import wt.util.WTException;
public class ObjectFromContainer {
public static void main(String[] args) {
try{
    WTPart part=null;
    WTDocument doc=null;
    EPMDocument epm=null;
    Persistable[] pers=null;
    String name="Test Lib";
    // * Entering QuerySpec for multiple query statements by CompositeQuerySpec
    CompositeQuerySpec cqs = new CompositeQuerySpec();
   cqs.addComponent(statementspecGenerator(WTPart.class,"TestProduct"));
   cqs.addComponent(statementspecGenerator(WTDocument.class,name));
   cqs.addComponent(statementspecGenerator(EPMDocument.class, "TestProduct"));
    QueryResult queryResult2 =  PersistenceHelper.manager.find((StatementSpec)cqs);
    System.out.println(queryResult2.size());
    while(queryResult2.hasMoreElements())
        pers=(Persistable[]) queryResult2.nextElement();
        for(Persistable p:pers)
            // * Changing the LifeCycleState of the objects As given
            if(p instanceof WTPart)
                part=(WTPart) p;
                System.out.println("Parts are"+((WTPart) p).getName());
            else if(p instanceof WTDocument)
                doc=(WTDocument) p;
                System.out.println("Documents are"+((WTDocument) p).getName());
            else if(p instanceof EPMDocument)
                epm=(EPMDocument) p;
                System.out.println("EPM's are"+((EPMDocument) p).getName());
    System.out.println("*******All Process Completed *********");
catch(QueryException e)
  e.printStackTrace();
} catch (WTException e) {
  // TODO Auto-generated catch block
@SuppressWarnings("unchecked")
private static StatementSpec statementspecGenerator(Class c,String contName) throws WTException
    QuerySpec queryspec = new QuerySpec(c);
    queryspec.isAdvancedQueryEnabled();
    SearchCondition sc1 = new SearchCondition(c, "containerReference.key.id",PDMLinkProduct.class, wt.util.WTAttributeNameIfc.ID_NAME);
    queryspec.appendWhere(sc1, new int[] { 0, contIndex });
    SearchCondition scSWPart = new SearchCondition(PDMLinkProduct.class ,"containerInfo.name",SearchCondition.EQUAL,contName,true);
    queryspec.appendWhere(scSWPart, new int[] {  contIndex });
return (StatementSpec)queryspec;
// For WTLiberyext.racing.ObjectFromContainer
private static StatementSpec statementspecGeneratorLibrary(Class c,String contName) throws WTException{
  int contIndex = queryspec.appendClassList(WTLibrary.class, false);
  SearchCondition sc1 = new SearchCondition(c,"containerReferene.key.id",WTLibrary.class,wt.util.WTAttributeNameIfc.ID_NAME);
  queryspec.appendWhere(sc1, new int[]{ 0, contIndex });
  SearchCondition scSWPart = new SearchCondition(WTLibrary.class,"conatinerInfo.name",SearchCondition.EQUAL,contName,true);
  queryspec.appendWhere(scSWPart,new int[]{contIndex});
// when i call statementspecGeneratorLibrary method i am getting error.
Please guide me.
Vivek
