I'm not sure if the object is present or not present in Windchill
Hi Joseph,
The object you are searching might be at -1 revision, but the value does not exist in Revision series.
Have you made any changes to the Revision series?
Bhagirath
Hi Joseph,
Bhagirath
Hello Bhagirath,
There was some revision naming issue hence this object was not visble.My seniors were able to check get the required revision from DB.\
Thank you for your inputs
