Attempting to install. Can't figure out what software download it's looking for for Service Pack - please see attached. I've installed Windchill many, many dozens of times - never ran into this before.
Aha - got help from tech support. Have to use the solution installed launched from the CPS 020 bundle.
So.... Install successful starting solutions installer this way. But, had to create a database manually (Oracle) first. Not sure why but it allowed it to get past OCU. May be helpful to others.
Did you set SQLNET.AUTHENTICATION_SERVICES to "NONE" in the sqlnet.ora file?
By default the property SQLNET.AUTHENTICATION_SERVICES is set to "NTS".
I had to reboot for another reason in the middle of the install and so wiped out what I had and started over, with everything removed and clean. On second try, it all worked perfectly - starting with "setup" under the CPS01 bundle DVD, not the Solutions Installer.
