I'm trying to upload a new drawing for existing part which is already in windchill. Here is there any
way to get the initial drawing revision same as WTPart while uploading drawing for first time..
Potentially, it depends on your REVISE preference settings
The preference Allow Override On Create CAD Document set to “Yes” should allow you to specify the same revision as the Part when initially creating the CAD document for the drawing
