I have an existing report template in our Production system that is linked to a report as well as several saved reports. I've developed a new version of it in our Development environment, and I'd like to load the updated report via QML and have everything downstream update accordingly. Is this possible?
Normal behavior when you load via QML with the same name is that it will add a 1 on the end so you end up with 2 reports
@joe_morton This article was just posted.
CS326585 How to update a template from the command line without deleting and loading in new Reports in Windchill PDMLink
Andrew
Andrew
