Bill,
Have you looked at doing this with a Move-Obects webject?
You could create an Info*Engine task with two webjects.
a Query-Obects webject to find th eobjects to be moved
then you would pass the Object IDs from the output of the Query-Objects webject to the Move-Obects webect.
The Move-Obects webect would then do the move.
Also keep in mind you can move the folder object that your obects are in. That might be a quick way to do this.
If you need more help,
Let me know.
In Reply to Bill Kunz:
What is the best way to move a large number of files from on context to another, thousands of files.
Please don't ask why we want to do this, let's just assume we have a good reason.
I have tried the standard GUI methods such as "Cut & Paste" and "Move" but find these very time consuming and I am not sure I can trust them for thousands of files.
Any idea on a command line approach or Oracle ?
Bill Kunz
Sr Engr (MCAD Specialist)
15800 Alton Pkwy, Irvine, CA 92618, USA
T +0 949 753 6709
[cid:image001.gif@01CD9279.056CFFE0]
You may need to buy info*engine licenses for every Windchill license if you want to utilize info*engine programming...not 100% sure, but I think PTC requires. it...
