I remember something like this when we first went to intra-link and the solution for me was to edit your psf file and remove the line which said ENV=INTRALINK_DIR=C:\ptc\proiclient.
In Reply to Michael Wimberly:
I search within the forum for the answer to this and couldn't find one so I am bringing it back to the group. What is the setting that needs to be changed to stop the user from getting multiple log in screens for Intralink, one when you start Intralink and another when you launch a linked session of ProE?
TIA
Michael Wimberly
Engineering Applications Support Specialist III
Security & Survivability
BAE Systems Land & Armaments
9113 Le Saint Drive
Fairfield, Ohio 45014 U.S.A.
(513) 881-4843 Direct
(513) 833-3565 Mobile
(513) 881-5087 Fax
-<mailto:->
P Before printing, think about the environment.
