I am receiving these 5 script errors every time I boot up Windchill and I am trying to figure out the root cause of these. They seem to be caused when loading the home page, and once I click "no" on all of them I can use WGM just fine.
Mark
Change the homepage in your wgmclient.ini file to something other than PTC homepage and these errors should go away.
That did the trick, is there any reason why the default home page causes these errors?
