Hi, I'm SeonHo
I want to write a retention rule and send Windchill's data to the Vault.
I maked new rules through ptc e support site/help
WTObject was sent to the Vault in every lifecycle state
However, did not send it to the Vault when I check in.
My question is two.
For check in & upload via Creo or other 3D CAD, is the file moved to the Vault only?
If i set wt.fv.useVaultsForAllContent to true, the data in Windchill is also moved to the repository?
Hi SeonHo
Here are the answer to the questions :
> Yes, check in from Creo Parametric or CAD tools goes to vault, if the vaults have been configured. If vaults are not configured with Windchill then data are stored into Database.
> Here's the description of property wt.fv.useVaultsForAllContent :
Hi SeonHo
