No new representation on Check in, new representation only on state change.
AR_10666332
I have a peculiar request, as the customer is reliant on Visualization primarily for taking PDF of drawings and again usually for release activities or change processes.
 I want to be able to get a new representation only on State change, which is done by enabling publish.republishonepmdocumentchange=true. The other half of the issue is to disable new representation creation on check in or on iteration.
So far I found publish.service.ignoredefaultepmevents property which I believe also prevents Ready to publish events from publishing, hence it does not allow even a state change to publish.
I'm also interested in the property publish.copyrepresentationsforward.restrict and what does it mean by copying a representation forward and if this can be used in this solution.
Thank you.
you can restrict publishing events upon check in operation using publishrules.xml, https://www.ptc.com/en/support/article/CS115536 this may help you. Simply you need to remove/comment out "publish on = "checkin" " and add  " publish on = "unknown-source" " along with properties suggested into the article.
If publish.copyrepresentationsforward.restrict set to True, it will Restricted representation copy forward mode. It does not copy a published representation forward when a WTPart iterates.
Hemant
Hemant
I will try this solution and get back to you.
So far I have not started used publish rules.
Thank you.
