What can the following code be used to do?
public class trainingResource extends WTListResourceBundle{
@RBEntry("hello, {0}!!!")
@RBComment("Bundle \"hello world\" example")
@RBArgComment0("a noun")
public static final String HELLO="0";
can it Define a new localized value or is it missing the @RBUUID annotation on the class?
Hi Serge,
Yes, you need to have the @RBUUID Annotation, the same value can be used in your action model files to refer to the resource files. For most of the OOTB resource file, you can find the source files in the Windchill installation directory.
e.g. <WT_HOME>\src\com\ptc\core\ui\navigationRB.java
Bhushan
Serge, did Bushan's explanation answer your question? If so, could you please mark the thread as answered so that others may easily know that the thread has a solution?
