Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Thus anyone encounter that proE prematurely exits during file upload or direct check-in in Intralink 9.0? it happens to some of my parts and assembly while trying to upload or direct check-in. I'm using WF4.0 M050, hope anyone could help me with this, I don't know if this is some kind of bug in intralink 9.0? Thanks, Jay
Hi Jay, If i am not correct you might be working on a very big assembly i.,e with a huge data. also you should check your system configuration aslo i mean your processor. if you are working with a 32-bit processor it supports only 1.5 gb to 2 gb ram max. if u r exceeding this the pro-e exits. ask your system administrator to increase your virtual memory or its better if you work on 64-bit proessor. it works without any issues.
