We have a requirement where we need to prompt the method server error to user in Windchill GUI.
Problem description:-
When a Windchill user tries to check in data from PLM to SAP and if for some reason data couldn't be transferred from PLM to SAP, then SAP responses the error to Windchill PLM which comes in method server log; However we want to show that error to user in Windchill GUI. But, we are not sure about the Windchill API to use here.
Looking forward for your valuable suggestions.
Thanks in advance.
Hi.
There are couple of APIs at SAP which, can be used to fetch the error logs created at SAP. If you are interested, I can help you on this...
Guru
