Query Builder Report - Parts linked to Resource
GianpaoloGallo
7-Bedrock
I try to have a Report with latest version of WTpart related to a list of Resouce ( Workcenter,Tooling..).
There is someone able to help me please?
Best regards
Gianpaolo
I have a report that links materials, equipment, cycles, operations, and work centers.
The name of the table labels are in Italian but it should not be difficult to retrieve the internal name from query builder.
The definitions table is used, trough criteria, to perform a join (my consultant's suggestion)
Marco
Ciao Gianpaolo,
retrieving the latest version in the query builder reports is not exactly easy.
Below you can find some examples of ready-made reports containing the filter on the latest version for various types of objects
How to build a report for latest version of EPMDocuments
Report that lists the latest versions for documents
How to select the latest revision of a Part in a Query Builder report
Marco
In case you also have multiple views of the same object (Design, Manufacturing, Plant) it is even more complicated.
Here is a link to a discussion on the subject.
https://community.ptc.com/t5/Windchill/Report-to-list-WTParts-of-particular-view/td-p/96770
Marco
Hi Marco,
fetching the latest version is ok.
My scenario has 4 different Manufacturing Plants.
I need to build a report with connection between Resources and WTPart
Gianpaolo
Sorry Marco but I missed which kind of join I have to use.
Maybe It's not possible to have the direct link between WTPart and a resource.
My first idea was to use one link from WTPart to Process plan "where used" and Resources to Process plan "Where used"
Best regards
Gianpaolo
Hi Marco,
now I have the connection between WTPart of a "choosen" view and the process plan.
I need to use the link "where used" to connect Process plan to resource
Any Ideas?
Best regards
Marco
Great Marco,
It works as well !!
Many thanks
