Version: Windchill Below 11.0
Use Case: Hi, To create an arc movement between the jump between drops, in NC Assembly, there's an option called Retract_transition. You place it in the ARC_TRANSITION option and set the RETRACT_RADIUS. Following these steps from the manual, the line comes out straight, making a corner instead of an arc. I don't know why it's not arcing.
Description:
